GS2200-8HP firmware and reset files
stefan_l
stefan_l Posts: 2 image  Freshman Member
I'm looking for the reset and firmware files for the GS2200-8HP switch. I know it's old but this is for my home lab enviroment.
Best regards
Stefan
  • Zyxel_Tina
    Zyxel_Tina Posts: 694 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @stefan_l,
    The GS2200-8HP has reached its End-of-Life (EOL) status. However, you can still find the latest firmware, version 4.00(AAAW.4)C0, available for download in this comment.
    For resetting the switch, the GS2200 series does not feature a physical reset button. To restore factory defaults, you will need to use .bin and .rom files. This process involves connecting via a console cable and reloading these files, as detailed in this article.
    While the GS2200-8HP can still be used, for optimal performance and access to current support, we recommend exploring newer switch offerings like the GS2220 series.
    Zyxel Tina
  • Zyxel_Tina
    Hi @stefan_l,
    Zyxel Tina
