Zyxel RGS200-12P factory reset via serial
I have a Zyxel RGS200-12HP switch that I would like to factory reset. Unfortunately, I do not have any login password, so I can only access the device through the serial console.
Could you please provide the official procedure for:
- Reflashing or reinstalling the firmware via serial console (e.g., XMODEM, TFTP, or other supported methods).
- Performing a full factory reset if no Web GUI or SSH access is possible.
- Confirming which firmware file types are supported for recovery on this model (e.g.,
.bin,.rom).
Any step-by-step instructions or documentation links would be very helpful.
Thank you in advance for your support.
Hi @Livioburch
Please check if your console cable matches and if the baud rate is correct.
For the command, please check the private message I sent.
Zyxel Melen0 -
Why oh why you do not provide proper KB with instructions?
It is my unit, I can do whatever I want to it!?
SC0 -
Hi @scerazy
There have some security reasons, so we didn't write a KB for this process.
I have sent the steps to you via private message, please check.
Zyxel Melen0
- 591 USG FLEX H Series
- 478 News and Release
