MLO on NWE130BE - Performance slow with Iphone 16 Pro
Chris888
Chris888 Posts: 69 image  Ally Member
First Comment Friend Collector First Anniversary Community MVP
i use a NWE130BE - works very fine! Last firmware, linked with 2,5GGb to a 10Gb-Core-Switch and a 10Gb QNAP-NAS.
I set up a new SSID to test MLO a few days ago. My Win11-Laptop with Intel BE200 and 24H2 works fine with MLO. No issues, very stable. More than 4Gb/s with iperf3 against my Qnap.
Since yesterday i have a Iphone 16 Pro. Connected to MLO-SSID as well, Nebula shows "MLO-Connected" on all 3 bands. Everythings seems fine, but the connection is slow. Iperf3 only show 500kb/s (same settings as allways).
When i connect it to the "old" SSID (Wifi 7 without MLO), it shows 700k/s. Again slow, but better.
Any recommendations how to setup the connection or do better testing etc?
Regards
Christian
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,319 image  Zyxel Employee
    Hi @Chris888 ,
    I appreciate your feedback.
    FYI: Our internal testing showed no performance issues when connecting an iPhone 16 Pro to the NWA130BE's MLO SSID as well.
    Zyxel_Judy
    Untitled Image
«1
  • Zyxel_Judy
    Hi @Chris888 ,
    We haven't received similar reports from other users. Furthermore, based on your description, the Windows 11 laptop works well with the NWA130BE MLO SSID, suggesting there's likely no issue with the AP itself.
    We'll continue to monitor this situation. In the meantime, we recommend contacting Apple support to investigate potential issues with their wireless card.
    Zyxel_Judy
    Untitled Image
  • Chris888
    okay, i opened a ticket at Apple, too.
    Regards
    Christian
  • Chris888
    Today i´ve done some testing.
    What i found: When i setup the new SSID with MLO, i used all my APs. One of them (NWA55AXE) provide only Wifi6 and no MLO.
    Now i changed the SSID to only the NWA130BE.
    My Iphone now (It was allways connected to the Wifi7-AP!) provide 1,5GB/s within the same IPERF3-Test.
    Strange. :-)
    Regards
    Christian
  • Zyxel_Judy
    Hi @Chris888 ,
    Zyxel_Judy
    Untitled Image
  • Chris888
    Hi Judy,
    thanks. Only to be clear, 1,5Gb is not what i expected.
    I think it should be more than 3Gb.
    But internet is full of reports about "slow" WLAN with Iphone 16 and Wifi 7.
    Apple will find a solution…at the end it is a luxury problem.
    Regards
    Christian
  • Jody_Owens
    Jody_Owens Posts: 7 image  Freshman Member
    Did you get 1.5 up and down or was it upload only? I am seeing an issue with my iPhone 16 Pro Max getting around 600mb/s downstream and 1.3gb/s upstream.
  • Chris888
    I saw differences between up & doen. same as you.
    In the meantime i switched to a WBE660S…problems a gone.
  • Jody_Owens
    I wonder what the differences are on the WBE660S that would correct the problem. I am not seeing a lot of differences that stand out. Did you make any changes on the phone or everything stock?
  • Chris888
    No changes on phone etc, same switch-port, same config.
  • Jody_Owens
    That is strange that nothing else change and it works perfectly. I am trying to figure out what is going on with mine.
