Nebula Access Point Secondary DNS
Hi guys,
in the Nebula Access Point network configuration is not possible to assign a static IP as secondary DNS server and setting up the network using DHCP the access point gets only a primary DNS server.
I hope, soon as possible in the new firmware release we can setup a secondary DNS server.
Obviously nowadays if the first DNS server is unreachable, clients connected to the access point won't work correctly.
Best Regards,
Andrea
Hi @andppa ,
Thank you for your suggestion. We will carefully evaluate this feature.
In the meantime, we recommend using a known DNS server, such as Google Public DNS (8.8.8.8 or 8.8.4.4), to help maintain a stable wireless connection.
Zyxel_Judy
I 2nd this.... Should be two options. I've never seen a network device limited to one option.
Hmm its like that for standalone too but this is only for the AP not devices connecting through it so not too bad if the AP can't DNS?
There is still only one DNS, even when using DHCP, this is not ok for that price. You eather want to promote a professional product, or you work with public IPs, for a low quality product.
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
