Visio Stencils
Hello, where can I get the Visio Stencils for following products?
Firewalls:
Zyxel VPN100
Zyxel ATP500
Switches:
Zyxel XGS1930-28
Zyxel GS1350-12HP
Zyxel GS1200
Access Point:
Zyxel WAX620D-6E
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 399 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Dear @Anteo,
    Good day.
    You can download Visio Stencils for the Zyxel products via our Download Library.
    Here's the link:
    https://www.zyxel.com/global/en/support/download
    Thanks.
    Ivan
  • eddeig
    eddeig Posts: 9 image  Freshman Member
    I checked the Link, but it only shows firmware, datasheets and release notes, but NO Visio Stencils. Where do I find those MS-Visio Stencils? Also for End of Live Models.
    Many thanks for your help.
    Regards,
    Eddeig
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,136 image  Zyxel Employee
    Hi @eddeig
    Which model are you trying to find?
    Zyxel Melen
Service & License Help Center
