ZYXEL WSR30
Djordje
Hello, I bought 3 Zyxel MULTY U WSR30 devices to extend my Wi-Fi network. From the very beginning, I have had a problem with the Mylti app, which stops the installation of the device at the end and shows that it is disconnected when I try to run it, even though the WSR30 created a network on the main unit. I was not able to connect the other devices because the app is disconnected. Aplication version is 2.6.4.250701. Please help me.
Hi @Djordje
This is more likely the device is using old certificate. Let me send you a private message to schedule a remote with you to upgrade the certificate.
Zyxel Melen0 -
Hi, can you help me to? I have exact same problem.
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
