Migrationtool convert from usgflex200 to USG FLEX 50H ?
Why is this not possibly?
I don't need no longer the power of an usgflex200 and made a Trade -Up to an USG FLEX 50H
I am a little confused why this is not supported by the migrationtool.
Hi @SWW,
During the Config migration, we have to consider the config for each port.
Direct migration between different tier levels or models with varying numbers of ports is often not supported. For instance, converting from a USG FLEX 100 to a USG FLEX 500 is not supported, and similarly, your scenario from a USG FLEX 200 to a USG FLEX 50H (a lower tier) is not supported. Moreover, there are other reasons to consider, so we suggest converting the config to the same segment's device.
Thanks.
Ivan
Hi @SWW,
Thanks.
Ivan
So I take from this to forget the well promotet Config migration tool 😒
Being a admin is never easy
Starting over can sometimes be best to relook at rules and policies no longer needed.
- 603 USG FLEX H Series
- 480 News and Release
