Migrationtool convert from usgflex200 to USG FLEX 50H ?
SWW
SWW Posts: 3 image  Freshman Member
Why is this not possibly?
I don't need no longer the power of an usgflex200 and made a Trade -Up to an USG FLEX 50H
I am a little confused why this is not supported by the migrationtool.
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 404 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Hi @SWW,
    During the Config migration, we have to consider the config for each port.
    Direct migration between different tier levels or models with varying numbers of ports is often not supported. For instance, converting from a USG FLEX 100 to a USG FLEX 500 is not supported, and similarly, your scenario from a USG FLEX 200 to a USG FLEX 50H (a lower tier) is not supported. Moreover, there are other reasons to consider, so we suggest converting the config to the same segment's device.
    Thanks.
    Ivan
  • Zyxel_Ivan
    Hi @SWW,
    Thanks.
    Ivan
  • SWW
    So I take from this to forget the well promotet Config migration tool 😒
    PeterUK Posts: 4,334 image  Guru Member
    Being a admin is never easy
    Starting over can sometimes be best to relook at rules and policies no longer needed.
Service & License Help Center
