Idea 4: rename objects
Dpj
Dpj Posts: 215 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
It would be nice if it will be possible when you can rename objects for example security policies. At the moment when you have saved the policy, you cannot edit the name anymore.
2 votes
Active · Last Updated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,650 image  Zyxel Employee
    edited September 2025
    Hi @Dpj
    Since our firewall (uOS & ZLD) use security policy's name as a key object, therefore, we can't support renaming the security policy's name. However, you can configure the security description as a workaround, or delete the security policy to configure the new name.
    Zyxel Melen
Nebula Tips & Tricks
