GS1900-8 with port 5 at VLAN1 - PORT 5-6-7 at VLAN 2-3-4
Hi @rainman70,
Welcome to Zyxel Community!
We would like to better understand your intended application, especially this part:
The purpose is to redirect a range of IP from VLAN 1 to VLAN2, a new IP range from VLAN 1 to VLAN 3, and a new one range from VLAN1 to VLAN 4.
Could you please explain in more detail what you would like to achieve with this setup?
If your goal is to perform VLAN routing, please note that this cannot be done on the GS1900 series switch, since it is a Layer 2 device. To achieve inter-VLAN routing, you would need a Layer 3 switch, firewall, or router.
Zyxel Tina
Hi Tina
Glad to hear from you
I have a NODE RED linux platform running at 10.6.0.xxx .
I have to share this server network segment with 3 furthermore segments ( = VLAN )
Check below
VLAN 5 is for server 10.6.0.2 : PORT 4
VLAN 1 is at 192.168.1.100 for management : PORT5
VLAN 2 is at 172.26.200.xxx PORT 6
VLAN 3 is at 172.26.201.xxx PORT 7
VLAN 4 is at 172.26.202.xxx PORT 8
Regards
Diego0 -
Without a layer 3 switch the subnets a routed by your router.
Hi
Do you have a layer 3 model to suggest me ?
Regards
Diego
The XS1930-10 or XGS1935-28
So I take it you have a VLAN router with the subnets?
When setting up you have one default gateway the switch goes to you have subnet's on the XS1930-10 to ack as gateway's that your device point to for gateway so that VLAN traffic routes by switch and any other traffic for the internet routes by default gateway to your router.
Hi @rainman70,
As mentioned earlier, you will need a Layer 3 model for your network. You can consider the XS1930-10 or XGS1935-28, as they are both Lite-L3 Smart Managed Switches. Please feel free to share if you have any other questions.
XS1930 Series | 10/12-port 10G Multi-Gigabit Lite-L3 Smart Managed Switch | Zyxel Networks
Zyxel Tina
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
