Losing data in connection usage
GiuseppeR
GiuseppeR Posts: 644 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
when you want to see how much traffic a device had used during last 30 days and you select an app (for example Instagram):
And you have a change in DHCP (so same MAC address and different IP) there is NO way to see which was the traffic done with that MAC address with x.x.x.10 IP and which traffic was done with x.x.x.3 IP.
If you click on both Galaxy names (with x.x.x.10 or x.x.x.3 IPs) you see only x.x.x.3 data (because this is the most recent IP that the device received via DHCP):
This is a bug, how can I fix it?
I need the complete logs and graphs of traffic done with my networks.
Thanks in advance
«1
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,533 image  Zyxel Employee
    edited September 2025
    Hi @GiuseppeR
    Please help to enable Zyxel support access and tell me the organization's name. I will help to check this issue.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    sent you details and remote access via PM
    PeterUK Posts: 4,411 image  Guru Member
    IP/MAC binding to lock the IP on a given device would be the only way.
    Or you can have options for Nebula like track by MAC's only but list the IP's the device has had or track by IP only but list the MAC's this IP has had.
  • GiuseppeR
    When you manage wide networks it is uncomfortable to assign MAC/IP manually.
    So it would be better to have detailed traffic considering MAC/IP and the time that you are viewing.
  • Zyxel_Melen
    Hi @GiuseppeR
    Thanks for the privilege. This issue arises because the client object is based on IP & MAC addresses. Since the IP address for this client has been changed, Nebula treats it as a new client. Additionally, you can still check the application of this client with the previous IP address. Please navigate to the client page > firewall client and select the specific period you want to check, then you can find this client with the previous IP address. I will also send you a video as a guide.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    I see it, it's great.
    Does Zyxel plan to fix the issue directly from here:
    Or it is better to memorize the other path?
  • Zyxel_Melen
    Hi @GiuseppeR
    Thanks for your input. For this design, we are still clarifying for the next step. I will update once I get any further information.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR
    This case has a design limitation: it is an AP client on the all client page, from which the application will retrieve the data. The AP client is only filtered by MAC address, which causes the Nebula redirect to point to the latest client object. Since that, we will evaluate this case and see what we can improve.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    could it be helpful for you to still have the priviledge to access that ORG to improve that?
  • Zyxel_Melen
    Hi @GiuseppeR
    Since we know how to replicate this scenario, it is ok for you to disable the support privilege.
    Zyxel Melen
Nebula Tips & Tricks
