H series 1.35 Patch1 - Missing Mac filtering for SSIDs
GiuseppeR
GiuseppeR Posts: 515 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited August 24 in USG FLEX H Series
Hello everyone,
using Flex/ATP series you can configure specific MAC filtering for specific SSID.
For example you can set more SSIDs with optional deny/allow lists.
Where the same function is on Flex H series with latest firmware?
Have a nice evening
  • Zyxel_Lynn
    Zyxel_Lynn Posts: 80 image  Ally Member
    Hi @GiuseppeR ,
    To configure MAC filtering for specific devices on H series, please follow these steps:
    Step 1: Navigate to Policy Clients
    Go to Wireless > WLAN Clients > Policy Clients.
    Click the "Add Policy Clients" button.
    Step 2
    A configuration window will appear.
    Click the "Add MAC" button
    Step 3: Add Device MAC Address for specific policy
    A new input window will open.
    Enter the MAC address of the target device.
    Select the desired policy type:
    Block Policy - Prevents the device from connecting
    To Specific SSID - Restricts the device to a particular network
    Apply the settings to activate the policy.
    This is how to configure the MAC filtering feature on H series devices. If you have any questions or need additional assistance, please don't hesitate to contact our support team.
    Best Regard,
    Lynn
  • GiuseppeR
    Hi @Zyxel_Lynn
    I have see that area, but there you can set a specific MAC address to enter or not a specific SSID.
    But you have to know the MAC address to block its pairing to a SSID.
    And if you have unknow MAC addresses?
    What I'm looking for is the "old style" MAC filtering, that was more efficient: everything blocked except listed MAC addresses for specific SSIDs.
  • Zyxel_Lynn
    Hi @GiuseppeR ,
    The H series allows SSID-specific MAC filtering through the Policy Client Configuration window. After entering a device's MAC address and selecting 'To specific SSID' policy, you can choose Normal (allow access) or Block (deny access) for that specific wireless network.
    Hope this help.
    Best Regard,
    Lynn
    PeterUK Posts: 4,140 image  Guru Member
    edited September 5
    I have to admit I don't get the layout…
    But whats being asked is a default policy to block all MAC's on a given SSID but a allowed list for that given SSID
  • GiuseppeR
    Exactly, all the Flex and ATP series could do that.
    It is impossible not to have that on a H Series
