GS1900-8 with port 5 at VLAN1 - PORT 5-6-7 at VLAN 2-3-4
rainman70
rainman70 Posts: 4 image  Freshman Member
Hi
I am not skilled on VLAN and TRUNK. I have to connect VLAN 1 on port 5 with a trunck to 3 VLANS . The purpose is to redirect a range of IP from VLAN 1 to VLAN2 , an new IP range from VLAN 1 to VLAN 3 and a new one range from VLAN1 to VLAN 4
  • Zyxel_Tina
    Zyxel_Tina Posts: 270 image  Master Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 50 Answers First Comment
    edited September 4
    Hi @rainman70,
    Welcome to Zyxel Community!
    We would like to better understand your intended application, especially this part:
    The purpose is to redirect a range of IP from VLAN 1 to VLAN2, a new IP range from VLAN 1 to VLAN 3, and a new one range from VLAN1 to VLAN 4.
    Could you please explain in more detail what you would like to achieve with this setup?
    If your goal is to perform VLAN routing, please note that this cannot be done on the GS1900 series switch, since it is a Layer 2 device. To achieve inter-VLAN routing, you would need a Layer 3 switch, firewall, or router.
    Zyxel Tina
  • rainman70
    Hi Tina
    Glad to hear from you
    I have a NODE RED linux platform running at 10.6.0.xxx .
    I have to share this server network segment with 3 furthermore segments ( = VLAN )
    Check below
    VLAN 5 is for server 10.6.0.2 : PORT 4
    VLAN 1 is at 192.168.1.100 for management : PORT5
    VLAN 2 is at 172.26.200.xxx PORT 6
    VLAN 3 is at 172.26.201.xxx PORT 7
    VLAN 4 is at 172.26.202.xxx PORT 8
    Regards
    Diego
    PeterUK Posts: 4,099 image  Guru Member
    Without a layer 3 switch the subnets a routed by your router.
  • rainman70
    Hi
    Do you have a layer 3 model to suggest me ?
    Regards
    Diego
    edited September 5
    The XS1930-10 or XGS1935-28
    So I take it you have a VLAN router with the subnets?
    When setting up you have one default gateway the switch goes to you have subnet's on the XS1930-10 to ack as gateway's that your device point to for gateway so that VLAN traffic routes by switch and any other traffic for the internet routes by default gateway to your router.
  • Zyxel_Tina
    Hi @rainman70,
    As mentioned earlier, you will need a Layer 3 model for your network. You can consider the XS1930-10 or XGS1935-28, as they are both Lite-L3 Smart Managed Switches. Please feel free to share if you have any other questions.
    XS1930 Series | 10/12-port 10G Multi-Gigabit Lite-L3 Smart Managed Switch | Zyxel Networks
    XGS1935 Series | 24/48-port GbE Lite-L3 Smart Managed Switch with 4 10G Uplink - Overview | Zyxel Networks
    Zyxel Tina
