Is there an issue with the guest wifi working on the usg20w-VPN with firmware version 4.33(ABAR.0)?
Arktech
Arktech Posts: 2 image  Freshman Member
edited April 2021 in Security
I am setting this brand new FW and the wizard said it was successful in easy mode but there is no internet connection. I found a KB and followed steps to set up a policy to allow it but that did not work either.
The main wifi connection has worked from the start after a NAT rule was setup because the ISP modem is bridged over to this FW.
  • Arktech
    Resolved by going to Configuration > Interface > Ethernet (tab) and changing the Guest configuration zone to Guest.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,435 image  Zyxel Employee
    Hi @Arktech
    It's good to heard you found the reason of it. :+1:
