USG FLEX 50AX Wifi
Aballo
Aballo Posts: 19 image  Freshman Member
When devices are wired to the USG, they got an IP (DHCP was enabled).
But when we try using Wifi, they didn't get IP… Why ?
Many thank's
L.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,356 image  Zyxel Employee
    Hi @Aballo
    What's your built-in AP SSID setting for the outgoing interface?
    Did you configure the correct interface? Does this interface have DHCP server?
    Zyxel Melen
  • Aballo
    It's lan1.
  • Zyxel_Melen
    Hi @Aballo
    I did a local test and I can get an IP from the built-in AP.
    Please check if your DHCP server pool is full. If so, please enlarge the pool size in the LAN interface configuration page.
    Zyxel Melen
  • Aballo
    The problem comes from Windows. We did a re-installation from scratch and all is now ok.
    Thank's for your help, and sorry for lost time…
