Zyxel GS1200-5HP v2 does not forward traffic within the same VLAN
jtk
jtk Posts: 25 image  Freshman Member
I have the VLAN configuration above (for ports 03 and 04 there are no other active VLANs). For some reason the switch does not forward packets between ports 03 and 04, but traffic to port 05 (the trunk port towards the firewall/router with the gateway ip of the VLAN) works.
Any ideas on how to allow traffic within the same VLAN on the switch?
There is no link aggregation used.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,593 image  Zyxel Employee
    edited September 2025 Answer ✓
    Hi @jtk
    It seems like you have enabled Port Isolation.
    Could you check the setting in the page Port > Advanced Settings?
    Zyxel Melen
    PeterUK Posts: 4,416 image  Guru Member
    Maybe the devices on ports 3 and 4 have a firewall
  • jtk
    No. I can ssh both of them from a different VLAN, while connection comes from the router via the trunk port 5. But I cannot ssh, ping or anything from each other.
    Can you Wireshark on one device then ping from the other device to the one doing the Wireshark with filter
    icmp or arp
    You should see a broadcast ARP with who has IP seen by any the one running the Wireshark and IP of that is as this MAC in reply
    The other reason could be that one or both devices use subnet 255.255.255.255
  • Zyxel_Melen
    Hi @jtk
    Zyxel Melen
  • jtk
    This was it! Thank you. For some reason it was very difficult for me to find the setting even after you pointed that out.
    Thank you for both of you for helping out!
