Zyxel GS1200-5HP v2 does not forward traffic within the same VLAN
I have the VLAN configuration above (for ports 03 and 04 there are no other active VLANs). For some reason the switch does not forward packets between ports 03 and 04, but traffic to port 05 (the trunk port towards the firewall/router with the gateway ip of the VLAN) works.
Any ideas on how to allow traffic within the same VLAN on the switch?
There is no link aggregation used.
Hi @jtk
It seems like you have enabled Port Isolation.
Could you check the setting in the page Port > Advanced Settings?
Zyxel Melen0
Maybe the devices on ports 3 and 4 have a firewall
No. I can ssh both of them from a different VLAN, while connection comes from the router via the trunk port 5. But I cannot ssh, ping or anything from each other.
Can you Wireshark on one device then ping from the other device to the one doing the Wireshark with filter
icmp or arp
You should see a broadcast ARP with who has IP seen by any the one running the Wireshark and IP of that is as this MAC in reply
The other reason could be that one or both devices use subnet 255.255.255.255
Hi @jtk
Zyxel Melen0 -
This was it! Thank you. For some reason it was very difficult for me to find the setting even after you pointed that out.
Thank you for both of you for helping out!
- 441 Beta Program
- 210 Nebula Ideas
- 540 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
