Permanent banner for scheduled regular upgrade
Hello everyone,
during these days if you enter an ORG with a SCR50AXE that is planned to be upgraded, you see this banner:
The problem is that it remains there also when you change to another ORG with 60 LITE or Flex just updated to latest firmware.
If you click on its X to close it, and then you go to another SCR50AXE ORG you cannot see it again also if that ORG needs firmware update.
That's strange 😁
Hi @GiuseppeR
Thanks you to point this out. This could be an issue when change org. I can replicate this issue and we are investigating it. I will keep you updated.
Zyxel Melen0 -
Hi @Zyxel_Melen
I have the same bar:
Also going from one ORG that has a Flex 200H to be updated to another one where everything is up to date, as you can see below:
Hi @GiuseppeR
Thanks for the further information. We have addressed this issue, and the fixed schedule is set for December. I will update here if the fix is done.
Zyxel Melen0
- 441 Beta Program
- 210 Nebula Ideas
- 540 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
