I can't configure the Zywall VPN 300 for VPN L2TP
2»
  • Andrei_Mazilu
    Andrei_Mazilu Posts: 9 image  Freshman Member
    The port forwarding config is made on ISP Router and i have made that NAT Rule also
  • Andrei_Mazilu
    I don't think is wrong if the message is received and the only thing that stops is because of a proposal mismatch, and the key group is the same.
  • Andrei_Mazilu
    Thank you Stanley for your help everything works fine now.
  • Zyxel_Stanley
    Hi @Andrei_Mazilu
    As your environment, WAN interface of VPN300 is public IP address.
    So port forwarding on ISP router is unnecessary.
    It’s good to know your issue has resolved. :+1:
