XMG1915 - Configure ports to allow VLAN traffic. pfsense -> Switch -> AccessPoint
Sathish
Sathish Posts: 2 image  Freshman Member
Thank you for taking time to help configure the switch. I am very new to switch usage.
I have several VLANS defined in my pfsense and was able to access them with an access point. I am unable to access the same after adding a switch between these two. Need some help to understand how to enable VLAN traffic.
VLANS defined in pfSense IoT (VLAN#20), Guets(VLAN#30), Office(VLAN#40)
PfSense is connected on Port1 of the switch
AccessPoint is connected on port8.
  • Zyxel_Tina
    Zyxel_Tina Posts: 687 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Sathish,
    Welcome to Zyxel Community!
    To enable VLAN traffic on your XMG1915 switch between your pfSense and Access Point, you need to configure both Port 1 (pfSense) and Port 8 (AP) as trunk ports. This allows them to carry traffic for multiple VLANs.
    Here's how to set it up:
    1. Access the Switch's Web Interface: Log in to your XMG1915's web GUI.
    2. Create VLANs:
      • Navigate to SWITCHING > VLAN > VLAN Setup > Static VLAN.
      • Add VLANs 20, 30, and 40. Ensure each is active.
    3. Configure VLAN Port Settings:
      • Go to SWITCHING > VLAN > VLAN Setup > VLAN Port Setup.
      • For Port 1 (pfSense connection):
        • For VLANs 20, 30, and 40, set Port 1 as Fixed and ensure Tx Tagging is checked (tagged).
        • Set the PVID for Port 1 to 1.
      • For Port 8 (AP connection):
        • For VLANs 20, 30, and 40, set Port 8 as Fixed and ensure Tx Tagging is checked (tagged).
        • Set the PVID for Port 8 to 1.
    This configuration will allow your switch to correctly pass the tagged VLAN traffic from pfSense to your AP and vice-versa. The AP will then handle tagging traffic from its SSIDs with the appropriate VLAN IDs.
    For detailed instructions, please refer to this FAQ.
    Zyxel Tina
  • Zyxel_Tina
    Hi @Sathish,
    2. Create VLANs:
    Zyxel Tina
