"Firewall clients by usage" not including VPN clients
GiuseppeR
GiuseppeR Posts: 657 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
edited September 2025 in Nebula
Hello everyone,
as you can see:
the firewall itself can see and highlight a remote backup (from another Zyxel FW with full VPN tunnel) but it is unable to list the remote client on the widget:
As you can see there is NO client with 20 gigs of traffic.
I think it is not properly displayed.
How can I fix it?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,586 image  Zyxel Employee
    Hi @GiuseppeR
    The reason of this issue is because the firewall in org A will not list the client on remote site via VPN as a client. But the traffic is still recorded since it passes through the firewall. This is the current behavior.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR
    I think this is related with this post?
    "Firewall Network application" not showing remote backup data — Zyxel Community
    May I know:
    1. Which type of VPN is it? Remote access VPN or site-to-site VPN?
    2. What's the topology?
    3. The NAS, backup server, is not in this site, correct?
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    no, two different issues.
    These widgets are from ORG1, on Nebula, based on USG FLEX 200.
    Here I set a Site-to-Site VPN for external partners.
    1. I have ORG2 with VPN from a USG FLEX 100HP, full tunnel VPN to Nebula parameters of ORG1
    2. ORG2 sends all the traffic to ORG1 and then goes to internet from ORG1
    3. The NAS is hosted on another site (you can consider it like ORG3) of a third party Company
  • Zyxel_Melen
    Hi @GiuseppeR
    Zyxel Melen
Nebula Tips & Tricks
