What can I do about Shell Scrip function?
Hello CHS,
G'day
On the Shell Scrip this feature,
user can enter the command in order to let device follow instruction and process automatically.
e.g. The device will backup the configuration before reboot
You can use schedule run by the following steps:(1) Upload a shell script to the device.
a. The contents of .zysh are:
copy /conf/startup-config.conf /conf/back-config.conf
b. save this file as "backupconf.zysh"
c. upload this file to shell scrip page. (Maintenance > File Manager > Shell Scrip)
(2) Use CLI command to run the schedule everyday:
Router(config)# schedule-run 1 backupconf.zysh daily 03:00
BR,
Charlie
Hey there CHS
I added a link with some scripts you can use for different things
https://webstore.zyxel.eu/public.php?service=files&t=85ca4cdf10de6545fa58f536fa005f4d
Kind regards
Mark
- 441 Beta Program
- 293 Service & License
- 461 News and Release
