"Firewall Network application" not showing remote backup data
GiuseppeR
GiuseppeR Posts: 480  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
I have a remote backup that seems to be invisible to this widget:
But in this ORG I setup a that remote backup that goes online with gigs of traffic:
the first client with more than 57 gigs of traffic is a server NAS.
How I can fix it?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,850  Guru Member
    Hi @GiuseppeR
    I think this is related with this post?
    This is the site with NAS, back up server, and connect with other sites with site-to-site VPN?
    Zyxel Melen
  • GiuseppeR
    edited September 22
    Hi @Zyxel_Melen
    no, this is another ORG.
    On the other post I used ORG1 and ORG2 and ORG3 (inside ORG3 there is the remote server NAS).
    So consider this issue as based on ORG4 (nothing to share with ORG1 and ORG2), saving data to ORG3.
    As you can see local server NAS on ORG4 sent a little bit less than 60 gigs of data to another server on ORG3 but "firewall network applications" on ORG4 does not show these 60 gigs while "firewall clients by usage" shows it.
  • GiuseppeR
    Right now I still have the same issue:
    while the other widget is OK:
  • Zyxel_Melen
    Hi @GiuseppeR
    May I know the application this NAS uses to send the data to org 3? I checked the application of this client in last 7 days, but I didn't find any application matches this traffic.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    the NAS is using Synology Hyper Backup to transfer and sync data.
Nebula Tips & Tricks
