connection issue,
I have 2 NWA50AX in my property, 1 seems to get 600 to 800mbs on connection tests with great connection to it, the other (sat just above the router) is only getting a connection of 80-100mbs changed the 2 around thinking it may be something faulty in the wiring, but same outcome when changed around, anyone got any idea what it could be or possible fixes
cheers for any help
Gary
Hi @Garywillis,
Welcome to Zyxel Community!
Just to confirm - when you say "changed the 2 around thinking it may be something faulty in the wiring, but same outcome when changed around”, do you mean that one of the APs always shows poor throughput, or that one of the locations always results in poor throughput?
To help us better assist you, could you please provide more information:
- Firmware versions of both APs
- Network topology (a diagram is welcome)
- Try to use different cables or locations to perform cross tests
- How you performed the connection test? Did you use the same client for both APs and locations?
- Any environmental factors, such as large electronics or metal objects near the AP?
In the meantime, please also refer to the following articles, which you may find helpful:
Zyxel Tina
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
