Flex H Models Routing Protocols e.g. BGP
2»
  • AMI
    AMI Posts: 25 image  Freshman Member
    Update. I installed the latest firmware, but with the previous firmware, it still had total lockup failure after some time. Only way to recover is to cold boot. I will get feedback from the customer if it happens again with the current image.
  • AMI
    edited September 2025
    But, here is another annoyance. Here are some console settings that are NOT on the web interface:
    running network-stack# conntrack
    <return> Validate command.
    | Add an output modifier.
    icmp-timeout Range: 1..300.
    Conntrack ICMP timeout.
    icmpv6-timeout Range: 1..300.
    Conntrack ICMPv6 timeout.
    max-entries Range: 16..10000000.
    Maximum number of Netfilter conntracks.
    tcp-timeout-close Range: 1..300.
    Conntrack TCP timeout close.
    tcp-timeout-close-wait
    Range: 1..300.
    Conntrack TCP timeout close wait.
    tcp-timeout-established
    Range: 1..432000.
    Conntrack TCP timeout established.
    tcp-timeout-fin-wait Range: 1..300.
    Conntrack TCP timeout fin wait.
    tcp-timeout-last-ack Range: 1..300.
    Conntrack TCP timeout last ack.
    tcp-timeout-max-retrans
    Range: 1..600.
    Conntrack TCP timeout max retrans.
    tcp-timeout-syn-recv Range: 1..300.
    Conntrack TCP timeout syn recv.
    tcp-timeout-syn-sent Range: 1..300.
    Conntrack TCP timeout syn sent.
    tcp-timeout-time-wait
    Range: 1..300.
    Conntrack TCP timeout time wait.
    tcp-timeout-unacknowledged
    Range: 1..600.
    Conntrack TCP timeout unacknowledged.
    udp-timeout Range: 1..28800.
    Conntrack UDP timeout.
    udp-timeout-stream Range: 1..28800.
    Conntrack UDP timeout stream.
    These are important settings in at least some cases, where sessions need to be open longer, so these need to be adjusted.
    What i cannot find are the default settings, as they are not visible in the running - but please enlighten me if there is a command to show ALL the config , even with the default values.
    There is this UPS software where delivery/pickup orders are uploaded via https.
    But the response is slow and it looks like it is running into a TCP timeout on the Firewall side, while the UPS website is keeping the session open which ends up in "blocked" messages in the firewall log and a failed upload.
    I had something like this on other firewalls and adjusting the half open sessions to a longer timeout.
    But without knowing the default values, it is difficult to figure out what to adjust.
  • AMI
    and what does this mean - IS-IS routing protocol is enabled?
    500H running config# vrf main routing isis
    enabled Default: true.
    Enable or disable IS-IS.
    instance Max count: 4294967295.
    Set IS-IS routing instance.
    This requires some explanation if this is some internal needed feature, otherwise it should not be enabled as it says per default it IS enabled.
