Permanent banner for scheduled regular upgrade
GiuseppeR
GiuseppeR Posts: 501 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
during these days if you enter an ORG with a SCR50AXE that is planned to be upgraded, you see this banner:
The problem is that it remains there also when you change to another ORG with 60 LITE or Flex just updated to latest firmware.
If you click on its X to close it, and then you go to another SCR50AXE ORG you cannot see it again also if that ORG needs firmware update.
That's strange 😁
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,904 image  Guru Member
    Hi @GiuseppeR
    Thanks you to point this out. This could be an issue when change org. I can replicate this issue and we are investigating it. I will keep you updated.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    I have the same bar:
    Also going from one ORG that has a Flex 200H to be updated to another one where everything is up to date, as you can see below:
  • Zyxel_Melen
    Hi @GiuseppeR
    Thanks for the further information. We have addressed this issue, and the fixed schedule is set for December. I will update here if the fix is done.
    Zyxel Melen
Nebula Tips & Tricks
