NWA130BE lost clients
DaveM84
DaveM84 Posts: 3 image  Freshman Member
In my NWA130BE with the latest two firmware versions, I have lost the client list.
Everything works fine, but there are no clients.
Firmwares:
V7.20(ACIL.1)
V7.20(ACIL.2)
Any ideas?
Thanks, everyone.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @DaveM84
    According to the screenshot, it is more likely your AP can't sync the system time with NTP server. With the wrong system time, Nebula could not display the correct current info.
    Please allow UDP 123 for *.pool.ntp.org & time.google.com on your router/firewall.
    Zyxel Melen
  • Zyxel_Melen
    Hi @DaveM84
    Zyxel Melen
  • DaveM84
    edited September 2025
    Thanks for the replay @Zyxel_Melen
    Bingo! AP log say: "NTP server update failed."
    But don't undestand why …
    The switch use the same *.pool.ntp.org and its work, while the AP fails.
    How can I investigate ?
    Thank you
    Dave
  • Zyxel_Melen
    edited December 2025
    Hi @DaveM84
    Please help to enable zyxel support access, we will help to check on this issue. I will send you a private message to confirm your device's mac address so we can find your org.
    https://community.zyxel.com/en/discussion/14234/nebula-how-to-turn-on-zyxel-support-access
    Update:
    Issue fixed by changing DNS server and NTP server.
    Zyxel Melen
