What can I do about Shell Scrip function?
CHS
CHS Posts: 181 image  Master Member
edited April 2021 in Security
In maintenance > File manager > Shell Scrip.
What can I do in this function?
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    Hello CHS,
    G'day
    On the Shell Scrip this feature,
    user can enter the command in order to let device follow instruction and process automatically.
    e.g. The device will backup the configuration before reboot
    You can use schedule run by the following steps:
    (1) Upload a shell script to the device.
    a. The contents of .zysh are:
    copy /conf/startup-config.conf /conf/back-config.conf
    b. save this file as "backupconf.zysh"
    c. upload this file to shell scrip page. (Maintenance > File Manager > Shell Scrip)
    (2) Use CLI command to run the schedule everyday:
    Router(config)# schedule-run 1 backupconf.zysh daily 03:00
    BR,
    Charlie
  • [Deleted User]
    [Deleted User] Posts: 118 image  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    Hey there CHS
    I added a link with some scripts you can use for different things
    https://webstore.zyxel.eu/public.php?service=files&t=85ca4cdf10de6545fa58f536fa005f4d
    Kind regards
    Mark
    Here a script I made for changing the DHCP Bootp flags to Unicast on OPT port
