Organization portal bug UI
GiuseppeR
GiuseppeR Posts: 539 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
as you can see with the latest Nebula update I have issues with web UI details.
You see columns also if they are NOT selected:
Selecting and deselecting again gives you the way to hide them effectively.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,134 image  Zyxel Employee
    Hi @GiuseppeR
    I checked some organizations with two accounts, but there's no such wrong display.
    Please share the org and enable Zyxel support access. We will investigate to determine the cause of the issue.
    Zyxel Melen
  • GiuseppeR
    Hello @Zyxel_Melen
    I see the issues among other ORGs too:
  • GiuseppeR
    Hi @Zyxel_Melen
    sent you a PM with a pair of examples with details to access those ORGs.
Nebula Tips & Tricks
