Blocking access to web sites
I sent a private message on 10 April 2019 and I still have had not had a response.Also per the other strand I still cannot update this box - it keeps on nagging me that still will not updateIf I do not get a response soon I am going to ask for a refund from my supplier and get a box that actually works properly0
ThThe issue about upgraiding is that the box says "Please note that your new firmware download feature is disabled due to ITS installed. Please contact local support to ensure the upgrade is applicable"
I have no idea what is "ITS".
Hi @Dovetail_MD
After checked configuration, you have added “cp.sobase.uk” in trusted website.
But custom service is disabled. So the rule will not work.
You can go to Configuration > UTM service > Content Filter > Office profile > Custom service > Tick " Enable Custom Service" box.
Then trusted web site you configured will work.
According to firmware upgrading error.
It is because You are using a special release firmware which may have specific enhancement in the firmware.
To avoid the firmware enhancement/changing missing after upgrading your firmware to the formal release version. Please check the changes in the release note before upgrading your firmware. You can download the latest formal release firmware from Myzyxel.com (https://portal.myzyxel.com/ ). After downloading the firmware, you have to upgrade your firmware from locally.
After unzip the firmware package, select “.bin” file to upgrade your USG60W.
Hi CharlieThank you concerning websites and the missing tick - so I am now well ticked off :-)If that does not translate as a joke, you may need to Google what ticked off means in the UK.Concerning the firmware, the "special release firmware" can only have come from the time when we 1st had this device and one of your colleagues had remote access to it to set it up in the way that we want.So I have no idea what are the "specific enhancement" - it may just be giving access to our local mail server through the firewall, which is no longer an issue - what did you spot as specific enhancement when you looked at the file I sent you?0
Also, there is not a ".ini" file in the zip file nor in the dropbox link you supplied - which file extension is the actual update please?
Hi @Dovetail_MD
There is no ".ini" file. When upgrading firmware ".bin" file is required
So you have to select "433AAKZ0C0.bin" to upgrade your USG60W.
Thank you CharlieSorry – I should read your emails more carefully - I have now gone through the process and it is just sitting there saying "Firmware upgrade in progress" and has been for the last 30 minutes0
Also, there is a warning in the upload box about using special release firmware - I assume I have been saddled with this by the person that help me set it up - any advice of getting out of this cul-de-sac would be most welcome
Hi @Dovetail_MD
After uploaded firmware to device, all of the sessions will closed and reboot system.
You can try to Ctrl + F5 to flush your browser after system boots up.
5 -
now dealt with0
- 384 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 79 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 910 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 898 Nebula FAQ
- 415 Security FAQ
- 234 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
