1.35FW Patch2 - Missing MLO WiFi parameters
GiuseppeR
GiuseppeR Posts: 615 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited October 2025 in USG FLEX H Series
Hello everyone,
I updated several H series FWs to latest firmware but I cannot see MLO options for WiFi managed:
Where can I find it to use all the hardware options of the APs installed on Clients' sites?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,467 image  Zyxel Employee
    Hi @GiuseppeR
    Since the WiFi 7 enforces new MLO change, the MLO option is not available on the configuration page, and enables by default. For more details, please reference this FAQ:
    Heads-Up: Latest WiFi 7 enforces new MLO change, Zyxel implement in 7.20! — Zyxel Community
    Zyxel Melen
  • GiuseppeR
    edited October 2025
    Hi @Zyxel_Melen
    thanks for that link, I missed it.
    So this is the reason why there is this change also on Nebula?
    So following this detail:
    And this detail:
    When you set a new SSID:
    • Old WiFi devices goes only to 2.4/5 GHz via "WPA2" when "WPA3 Transition Mode" is activated
    • MLO is enabled on 2.4/5 GHz when you select at least "WPA3 Transition Mode"
    • MLO is enabled on 6 GHz when you select natively "WPA3" OR it autoconverts to "WPA3" when you have selected "WPA3 Transition Mode"
    So selecting this:
    And this:
    Is the way to use MLO on 2.4 + 5 + 6 GHz…. Am I correct?
  • Zyxel_Melen
    Hi @GiuseppeR
    MLO feature is enforced enabled for every SSID on WiFi 7 device. The only option to disable MLO is to change the Radio setting for each band. Therefore, change SSID settings will not disable MLO.
    Zyxel Melen
  • GiuseppeR
    edited October 2025
    Hi @Zyxel_Melen
    very nice to know, so every AP "XYZbe" WiFi7 capable has MLO active per default.
    Do you mean the Radio settings that you can find here?
  • Zyxel_Melen
    Hi @GiuseppeR
    Yes. You can scroll down to adjust by each AP.
    Zyxel Melen
