1.35FW Patch2 - Missing MLO WiFi parameters
Hello everyone,
I updated several H series FWs to latest firmware but I cannot see MLO options for WiFi managed:
Where can I find it to use all the hardware options of the APs installed on Clients' sites?
Hi @GiuseppeR
Since the WiFi 7 enforces new MLO change, the MLO option is not available on the configuration page, and enables by default. For more details, please reference this FAQ:
Heads-Up: Latest WiFi 7 enforces new MLO change, Zyxel implement in 7.20! — Zyxel Community
Zyxel Melen0 -
Hi @Zyxel_Melen
thanks for that link, I missed it.
So this is the reason why there is this change also on Nebula?
So following this detail:
And this detail:
When you set a new SSID:
- Old WiFi devices goes only to 2.4/5 GHz via "WPA2" when "WPA3 Transition Mode" is activated
- MLO is enabled on 2.4/5 GHz when you select at least "WPA3 Transition Mode"
- MLO is enabled on 6 GHz when you select natively "WPA3" OR it autoconverts to "WPA3" when you have selected "WPA3 Transition Mode"
So selecting this:
And this:
Is the way to use MLO on 2.4 + 5 + 6 GHz…. Am I correct?
Hi @GiuseppeR
MLO feature is enforced enabled for every SSID on WiFi 7 device. The only option to disable MLO is to change the Radio setting for each band. Therefore, change SSID settings will not disable MLO.
Zyxel Melen0 -
Hi @Zyxel_Melen
very nice to know, so every AP "XYZbe" WiFi7 capable has MLO active per default.
Do you mean the Radio settings that you can find here?
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 343 Security Ideas
- 295 Service & License
- 471 News and Release
