WDS SSID is NOT hidden
Ikarus
Ikarus Posts: 20 image  Freshman Member
I managed to connect two AP’s via WDS.
But…. now I see an additional WiFi. I though the created profile will be used to connect the AP’s, so that they can “communicate” with each other.
So, here are my questions:
  1. I see now a new WiFi access point (SSID) available called “MyZyXELWDS”.
    1. I thought this will be used the connect the two devices and it is HIDDEN! image-2c5ff905bfc79-f50b.png
Thanks!
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,467 image  Zyxel Employee
    Hi @Ikarus
    Thanks for the information. This issue is because of the enforced MLO rules. It does not support a hidden SSID, therefore, the WDS SSID can't be hidden. For more details, please reference this link with highlight.
    P.S. MLO is enabled by default.
    Zyxel Melen
