minor bug
When i click the copy button behind "organization ID" in the right upper corner, i get the message cloud monitor id copied…
when i click the copy button behind "cloud monitor id", in the right upper corner i get the message organization id copied…
It's just the message which isn't correct.
Update
Issue has been fixed.
Zyxel Melen1
Hi @Dpj
We can replicate this issue, and is going to fix it. I will update here once the fix is done.
Zyxel Melen0 -
Update
Zyxel Melen1
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
