Better transparency for Security Filters (DNS / URL filtering)
tekkie
tekkie Posts: 11 image  Freshman Member
Hi everyone,
The security features are generally very good, but sometimes it’s not clear why exactly a website gets blocked.
In my case, the issue was first caused by the DNS filter, and later by the URL filter. It would be really helpful to have a way to test a domain directly in the interface and immediately see which filter or category is blocking it.
This would make troubleshooting and fine-tuning the security settings much faster and clearer for admins.
Best,
Valentin
1 votes
Completed · Last Updated
Already have this function.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,532 image  Zyxel Employee
    Hi @tekkie
    DNS/URL threat filter provides a test tool to check the category this domain belongs to. Please reference to the screenshots below.
    Zyxel Melen
  • tekkie
    Hi @ZyXEL _Melen,
    Yes, that makes sense and technically it works as expected. But in practice, the situation is often a bit different, a customer tells me that a website doesn’t work, so I ask for the domain and what message they saw. Then I see that the DNS filter blocked it, so I whitelist it there, but later it turns out that the URL filter blocks it as well.
    It would be really helpful to have one single interface where you can enter a domain or URL and have it checked across all filters, DNS, URL, SSL inspection, maybe even IP reputation. That would make troubleshooting much faster and more transparent.
    Best,
    Valentin
