WDS SSID is NOT hidden
I managed to connect two AP’s via WDS.
But…. now I see an additional WiFi. I though the created profile will be used to connect the AP’s, so that they can “communicate” with each other.
So, here are my questions:
- I see now a new WiFi access point (SSID) available called “MyZyXELWDS”.
- I thought this will be used the connect the two devices and it is HIDDEN!
Thanks!
Hi @Ikarus
May I know the model and fireware of this issue? This will help us to check it.
Zyxel Melen0 -
NWA210BE: V7.20(2) / 2025-08-26 12:52:01
NWA110AX: V7.10(3) / 2025-06-29 11:40:52Thank's for taking a look at it.
Hi @Ikarus
Thanks for the information. This issue is because of the enforced MLO rules. It does not support a hidden SSID, therefore, the WDS SSID can't be hidden. For more details, please reference this link with highlight.
P.S. MLO is enabled by default.
Zyxel Melen0 -
Hello @Zyxel_Melen,
Many thanks for the answer.
Yes, the 5G and 6G band is configured as 11be.
Just to clarify, is the WDS SSID hidden if the mode is 11ax?
Ikarus0 -
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
