L2 isolation is not working
Running_MAN
I use some APs for my guests to connect and L2 isolation to avoid they can connect to each other when they come to my office.
Recently, I changed my configuration to add captive portal and redirect them for using a QR code to access internet.
But, after I doing the captive portal setting, the L2 isolation is not working.
Shouldn't these two functions use at the same time?
Hi @Running_MAN
The two function can be use at the same time.
For your application, captive portal must redirect on controller.
You might have encounter the condition like that.
The tunnel mode is not allowed when using layer-2 isolation profile.
You must set
1. Forwarding mode to Local Bridge.
2. Change the topology let the traffic must go through controller to gateway.
For example: WAN-----gateway----NXC---switch---AP ) ) ( ( client
Kathy
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 456 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
