Templates Flexh series
Dpj
Dpj Posts: 215
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
image  Master Member
At the moment you can configure the H series in nebula first and then apply this configuration to a new firewall.
But an feature we realy miss: use this nebula config as an template for new customers.
This was really great with the Flex 200 series, and i don't understand why this is not possible with the flex h series. It takes so much more time now to configure many firewalls for new customers. Like we are MSP, it's important to very quickly roll out new firewalls. now you have to use config files, like we used before with the Zyxwall 110. In my opinion, this is not the way it should be in 2025.
I really hope this will be possible soon.
Yours dennis
1 votes
In Plan · Last Updated
ETA is 2026 1H.
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,169
    image  Zyxel Employee
    Hi @Dpj
    Just for confirm, do you mean the feature "Security profile sync"?
    Zyxel Melen
  • Dpj
    Dpj Posts: 215
    image  Master Member
    No what i did, i had an organziation with an usg flex 200. I made all the settings in the he flex 200, then when i go to Cross org site replication, and create an new organization, it copied the template from the flex 200 to this new organization. Next step was adding physically a new flex 200, and it took over the template i configured before.
  • Zyxel_Melen
    Hi @Dpj
    Thanks. I checked this is already in our roadmap and the current ETA is 2026 1H. If there has any update, I will let you know.
    Zyxel Melen
Nebula Tips & Tricks
