Remote Access IPSEC VPN doesn't work
Hi Peter - thanks so much for this detailled answer !
I did all of that - but you know what - I'll restart from scratch and will let you know.
Do you know if there is a way to use pre-shared instead of certificate for remote access (it should as you have this option in SecuExtender) ? Where do you configure the pre-shared on the GW side ?
Thanks again,
Have a good day
Hi Peter again,
You know what - it's working now !
I started all again, from scratch, including self-signed certificate generation. Actually my guess is that the first certificate I generated did not include the "Extended Key usage" checks ; I did check all of them for this new cert and it worked… But it's just a guess - might be something else ;-).
Now I have to manage NAT but it should be easier ;-)
Thanks a lot Peter for your time and your great help !!
All the Best,
Jerome
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
- 106 Security Highlight
