Hi Nebula team
saltet
saltet Posts: 76 image  Ally Member
In the last update of Nebula you added the function wifi alert insight.
I have from day one from I got to know about the function put the info on my dashboard.
But I do not get any information in the box.
see added image
It is the same for both of my organisations.
Is it only a license issue ? I use only base. Or is it more any more changes to make in Nebula to receive the information to the dashboard.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @saltet
    The wifi alert insight weight is based on Wireless heleath and WiFi Aid, which are Nebula Pro Pack features. Therefore, your organization needs to be a Pro organization to use wifi alert insight.
    Zyxel Melen
  • Zyxel_Melen
    Hi @saltet
    Zyxel Melen
  • saltet
    Thanks a lot for the answer.
Nebula Tips & Tricks
