how do I setup different schedules on different SSID's from the same AP
johnpalmer
johnpalmer Posts: 2 image  Freshman Member
  • Zyxel_Tina
    Zyxel_Tina Posts: 675 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @johnpalmer,
    You can configure different schedules for different SSIDs on the same access point by following the steps below, depending on your management mode:
    For Standalone mode:
    You can assign a specific time schedule to each SSID individually.
    1. Go to Configuration > Object > AP Profile > SSID to create or edit an SSID.
      1. How to create an SSID on Standalone mode — Zyxel Community
    2. Scroll down and check “Schedule SSID.”
    3. Set the desired enable/disable time for that SSID.
    For Nebula cloud-managed APs:
    You can configure different SSID schedules and apply them selectively to specific APs using tags.
    1. Configure the SSID and set its schedule by following this FAQ
      1. [NEBULA] How to configure SSID schedule? — Zyxel Community
    2. Then, use tags to apply specific SSIDs to particular APs
      1. How to configure unique SSID on specific Access Points on Nebula? — Zyxel Community
    3. In addition, the latest version of NCC has enhanced the SSID scheduling feature, enabling users to set multiple on/off periods for each day. Users can also easily duplicate a single day’s schedule to other weekdays. image.png
    This way, each SSID can have its own operating schedule, even when broadcasted from the same AP.
    Zyxel Tina
  • Zyxel_Tina
    Hi @johnpalmer,
    Zyxel Tina
