Radius server on ZyXEL FLEX H with SSL VPN
Recently upgraded to FLEX H series and in same time to WIndows Server 2025. We used to have AD Integration for VPN, so that users could be defined on AD. Classic implementation (TCP389) still works with new FLEX H series combined with SSL and OpenVPN Client.
But as we have to move on to Windows Server 2025, classic LDAP on TCP389 is phased out and now I'm testing Radius with NPS on Windows Server.
It seems my connection works(with certificate etc). But I still receive
Failed login attempt to Device from sslvpn (incorrect password or inexistent username)
In C:\Windows\System32\LogFiles\IN2510.log I get "WS2025","IAS",10/30/2025,11:58:14,1,"user","domain.local/Gebruikers/user",,,,,,"192.168.25.1",11396,0,"192.168.25.1","ZyXEL FLEX 50h",,,5,,,8,1,"Connections to other access servers",0,"311 1 192.168.25.2 10/30/2025 08:33:00 11",,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,"Use Windows authentication for all users",1,,,,
"WS2025","IAS",10/30/2025,11:58:14,3,,"domain.local/Gebruikers/user",,,,,,,,0,"192.168.25.1","ZyXEL FLEX 50h",,,,,,,1,"Connections to other access servers",65,"311 1 192.168.25.2 10/30/2025 08:33:00 11",,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,"Use Windows authentication for all users",1,,,,
I tried user@domain , user@domain.local , domain\user and user
But always wrong login/password
created ext-group-user, tried with both DistinguishedName and sAMAccountName, no difference.
Creating a local user on firewall works fine, so SSL VPN connection should be ok.
Not sure if it's now a config issue on flex or server?
Hi sorry but I can't help you, but if you have time can you explain me how I can have an AD integration on a SSL VPN? In my case the VPN is working but the client can't access a folder on a windows 2012 server of the LAN (in a domain ambient).
Why not using LDAPs (TCP 636) instead of RADIUS/NPS ?
Tried to follow that guide too, but something is missing here for me:
I don't have the possibility to enter my username, so tried just the Bind DN, but that's not working.
That's weird… In the manual it clearly says, go to LDAP
But ok, Tried now through AD and tested my account and I get Invalid DN Syntax.
I Think it has something to do with my certificate. I've exported it in computer certificates with default settings and imported it in Trusted Certificates.
The Bind user I created in AD I delegated control on OU where my VPN Users group is in.
Hi @nielsscheldeman,
Thank you for the information. To assist you further, could you please send us a private message with your configuration parameters? This will help us investigate the issue more thoroughly and provide you with an appropriate solution. Also, we appreciate you pointing out the error in our FAQ; we will make the necessary corrections. Thank you!
Zyxel Tina
So as I have a solution for WS2025/FLEX H, I still want to be able to use Radius, because ZyXEL doesn't have 2FA anymore, I'd like to use our Userlock console for it. This however depends on Radius.
I've been able now to connect the Flex H to Radius server, but only through unencrypted authentication(Chap). Is there a way to enable MS-Chap v2 for authentication? I don't see any option.
Also the other problem why my connection didn't work, was that I specified the Ext-Group-User. I've set it to any now and now I can connect. It's workable because Radius server now Grants or doesn't grant access.
But that means that I cannot set Security Policies on specific groups of users to access Network Resources.
So as I still don't have a solid 2FA solution with AD integration, and tried with OIDC, but that has come to a dead end too(support will be on 1.39, but now 1.38 has been released, but there are problems with that firmware too I think, because the webinar has been postponed :
OIDC Setup on FLEX H — Zyxel Community
I'm afraid that OIDC will take long time then.
So back to RADIUS, I have third party software to add MFA on that. But I first have to be able to connect Radius. First thing I see, that only PAP is supported… :( but ok then. Connection has been made and in NPAS Event viewer I see successfull NPS Granted access to a user.
But in Logs from FLEX 200H I get: user from (IP) not in allowed user list, followed by TLS Auth Error: Auth Username/password verification failed for peer.
I have created ext-group-user with correct group identifier from my AD and added in SSL VPN my primary server (Radius/Testradius) and the created ext-group-user as allowed users.
If I set in allowed users "any" but still use the Radius server, then I can login with my user from the server. So Radius works, but my ext-group-user is wrong I think? But the Group Identifier should be ok.
Ok so now I have left it on Any user since my NPS Server handles the security now, so no problem. It all works now, even with 2FA behind it from Third party.
But… :) after a day or multiple logins, it fails and I have to restart the VPN on the firewall. Could it be bugged? Or is Radius messing with me?
I can log in using my account from the server if I set the authorized users to "any" but continue to utilize the Radius server. Radius functions, however I believe my ext-group-user is incorrect. However, the Group Identifier ought to be acceptable.
- 237 Nebula Ideas
- 6.8K Security
- 743 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
