Misalignment with traffic meter "Access Point by usage" and "SSID by usage"
GiuseppeR
GiuseppeR Posts: 535 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
I have an ORG where a widget shows me bigger data exchanged wirelessly than another one of the same ORG.
As you can see it seems that I have had 1.6 gigs (last 24h):
with a 1.1 gigs from a specific AP, while looking at SSID usage it shows me to have had only half GB of traffic (last 24h):
I have no mesh WiFi activated, every AP is working purely as APs… so these APs traffic meters are not working properly.
How can I fix that?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,096 image  Zyxel Employee
    Hi @GiuseppeR
    May I know which AP model is it?
    Zyxel Melen
  • GiuseppeR
    edited October 28
    Hi @Zyxel_Melen
    on that site I have 6x NWA130BE with V7.20(ACIL.3) onboard :
    In this moment I see 4.2 gigs here:
    and about 3.4 gigs here:
  • Zyxel_Melen
    edited November 3
    Hi @GiuseppeR
    The "Access Point by usage" will record all the traffic on the AP, combine all SSIDs and the LAN port traffic(if the AP has the LAN port), therefore, the total traffic will be different to the SSIDs by usage, which record the traffic from a SSID of all APs in the same site.
    May you share the number of SSIDs in this site? Does the NWA130BE connect to any device on the LAN port?
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    I disabled LAN onboard:
    So only pure AP function.
    On that ORG I have 3 SSIDs linked to APs with tags.
  • Zyxel_Melen
    Hi @GiuseppeR
    Since we want to monitor the difference between "Access Point by usage" and "SSID by usage", could you help to enable Zyxel support access and share the organization's name with us? Thanks for the cooperation.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    sent a PM with details.
    In this moment:
Nebula Tips & Tricks
