Multiple IPsec connections of a single configuration
I use Zyxel FLEX 100 with firmware 5.41.
I noticed multiple IPsec connections of a single configuration. It looks like this in the VPN stats monitor:
Why there are multiple connections for the MASTER_VPN_VLAN200 configuration? Any advice is welcome, thank you.
There are 2 configuration using this IKEv2 gateway:
MASTER_VPN:
MASTER_VPN_VLAN200:
Gateway configuration:
There is pfSense on the other side of the tunnel:
Best Answers
I think the problem is you have one gateway for the two VPN connections
If you setup two gateways each with different encryption or local/remote ID for each VPN connection it should work better.
- 588 USG FLEX H Series
- 477 News and Release
