minor bug
When i click the copy button behind "organization ID" in the right upper corner, i get the message cloud monitor id copied…
when i click the copy button behind "cloud monitor id", in the right upper corner i get the message organization id copied…
It's just the message which isn't correct.
Update
Issue has been fixed.
Zyxel Melen1
Hi @Dpj
We can replicate this issue, and is going to fix it. I will update here once the fix is done.
Zyxel Melen0 -
Update
Zyxel Melen1
- 243 Nebula Ideas
- 6.9K Security
- 790 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 326 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
