how to create vpn ssl with client openvpn
Hi all,
I could make it work.
But when you enable 2FA for the VPN, you have to enable 2FA for all your users or they can't reach the LAN.
I thought you could enable 2FA for the users you want, and the other ones could use the VPN as usual, but apparently no.
So I don't understand why there is a box to check/uncheck 2FA for each user ?
Hi @rcd
Enabling 2FA stands for more security. Therefore, it is not a good way to enable 2FA for specific users, as it could cause security weaknesses.
Zyxel Melen0 -
On FLEX200 (non H)not per user but per IKE gateway which can be trickly to do two on one WAN IP you can enable or disable for that gateway for given user groups when 2FA is globally enabled.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
