how to create vpn ssl with client openvpn
2»
  • rcd
    rcd Posts: 4 image  Freshman Member
    Hi all,
    I could make it work.
    But when you enable 2FA for the VPN, you have to enable 2FA for all your users or they can't reach the LAN.
    I thought you could enable 2FA for the users you want, and the other ones could use the VPN as usual, but apparently no.
    So I don't understand why there is a box to check/uncheck 2FA for each user ?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,622 image  Zyxel Employee
    Hi @rcd
    Enabling 2FA stands for more security. Therefore, it is not a good way to enable 2FA for specific users, as it could cause security weaknesses.
    Zyxel Melen
    PeterUK Posts: 4,426 image  Guru Member
    edited November 2025
    On FLEX200 (non H)not per user but per IKE gateway which can be trickly to do two on one WAN IP you can enable or disable for that gateway for given user groups when 2FA is globally enabled.
