Can't upgrade GS1200-5HP v2
Minty95
Minty95 Posts: 3 image  Freshman Member
edited November 2025 in Switch
Hello
I have three GS1200-5HP v2, two are running v3 firmware., But this latest one, I unable to update it.
When I first ran the update for the v3 via the browser/web interface (I'm running Linux, as with the others), I soft-bricked it, and I had to run a 'curl' in terminal to get it back to v2. phew…. Here is exactly what happened and how I got around the soft-bricked switch.
How I unbricked it: https://deafbutnotdead.pagecord.com/zyxel-firmware-upgrade-was-failed-please-try-again
This is strange, as the other two are running v3.
Is it due to its serial number? Build version?
The PDF supplied with the .bin file does talk about the serial numbers, but the English is not very clear…
The v3 patch I tried is GS1200-5HP v2_2.00(ABKN.3)C0
My SN is S2243xxxxx
Though not very important, I would like to update if possible
Many thanks
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,676 image  Zyxel Employee
    edited November 2025 Answer ✓
    Hi @Minty95
    This issue is because
    1. The upload process takes longer in Ubuntu/Debian. Compare with Windows and the browser is Firefox.
    2. The Firefox takes longer than google chrome in Ubuntu/Debian, which over 30 seconds countdown.
    I tried using Ubuntu 24 with google chrome and upgrade without any issue. Please try google chrome again.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Minty95
    Zyxel Melen
  • Minty95
    The upload for the v3 takes just a couple of seconds when using curl, finishes with no errors, but doesn't change anything, as if it's not the correct file. (When I redid the curl update with v2, it took 3 mins)
    I'm going to try again with the web interface in a couple of days when I'm back on my Arch PC
