How to reset to factory settings NWA3550-N
Hi @Serega,
Welcome to the Zyxel Community!
Please note that the NWA3550-N is an older model and has been EOL for quite some time, so we do not have the physical device available for reference. Also, our support for this model is limited.
Could you please check if you can find a small reset button on your device similar to the one shown in the image below? If not, kindly provide us with detailed photos of your device.
Zyxel Tina
No button. No console/rst
Hi @Serega,
Since the NWA3550-N has been EoL for a long time, our support for this model is limited. We apologize for any inconvenience this may cause and appreciate your understanding.
Additionally, you may explore our newer wireless solutions on the official website. Thank you!
Zyxel Tina
Where can I find the technical support contacts for this company?
Hi @Serega,
Thank you for your inquiry, but we are unclear about your question. As mentioned, the NWA3550-N has been End of Life (EoL) for a long time. Therefore, we no longer have physical units available for reference and cannot provide any technical support for this model.
If you're considering upgrading to one of our current product models, we would be happy to assist you with those devices. You can explore our latest wireless solutions on our official website.
Zyxel Tina
Get yourself a console cable, and plug it into the console port and use a terminal software (e.g., PuTTY or Tera Term).
Even without an admin password, some firmware versions let you interrupt boot at the very first stage (boot loader) before the OS prompts for login.
There you may be able to issue a reset command or wipe the config. Can't remember the exact procedure, but upon interrupting the boot process, there will be a possibility to upload a factory-default config file (default-config.rom usually) that you have to upload with xkermit protocol.
This will reset it.
I recall this one had a small utility that could do it independently on its config, but I dunno where to get it from.0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
