USG 500H Import DHCP
MeatPopsicle
Upgrading from an older ATP200 to a new USG 500H and hoping to import the DHCP reservations from the ATP200 instead of having to type them all manually. I found an older post with a link to a tool that doesn't apply to the new device/firmware.
Is there any way to import DHCP reservations on the 500H?
You can:
- Use the convertor tool to get the DHCP reservations configuration.
- Download the startup-config from your firewall with the newer firmware version.
- Copy the DHCP reservations configuration from the converted config and paste to the startup-config from step 2.
- Upload it and apply.
Hope it helps.
Zyxel Melen0
You can:
Hope it helps.
Zyxel Melen0 -
This worked. There's no direct ATP200-USG500H conversion path but I was able to export the ATP200 config, export the USG500H config, compare the two, and copy/paste quite a few config lines and save myself a lot of time.
Thank you for the tip!
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
